32 bits...
Re: 32 bits...
Message 28 févr. 2013, 22:50
y'a pas 2 versions pour la CS6 ? une normale et l'extended ?
Re: 32 bits...
Message 28 févr. 2013, 23:06
Apparemment l'extended existe aussi pour la version cs6 : http://www.adobe.com/fr/products/photos ... rison.html
Mais le lien qui compare la version normale à l'extended ne précise rien sur les capacités du mode 32 bits.
Re: 32 bits...
Message 28 févr. 2013, 23:45
Je dois avoir l'extended au boulot, je checkerai lundi...
Re: 32 bits...
Message 01 mars 2013, 08:15
j'ai trouvé ça :
Support for painting and layers in 32-bit/HDR files. Merge to HDR is enhanced in both editions, as is basic HDR editing (e.g. using Levels).
Re: 32 bits...
Message 01 mars 2013, 11:04
Roch a écrit :j'ai trouvé ça :
Oui, j'ai testé la version extended et on retrouve notamment le calque d'exposition. La version de base de Photoshop pour du 32-bit color c'est nul.
Re: 32 bits...
Message 15 mars 2013, 23:50
Je viens de lire ceci sur le forum .com :
I recently saw an interesting Photoshop trick mentioned which I have to try out myself.
Say you have certain layers which you rather would like to keep 16bitish or higher but for the
rest you would like to work on 8 bit. Then you can select all these precious layers together
and turn them into a single smart object. Afterwards you can convert the document to
8 bit but the smart object keeps its higher bitdepth - internally.
Source : http://maxwellrender.com/forum/viewtopi ... 97&t=40210
Si cela s'avère vrai, c'est super !
Sinon dans la suite du message il y a écrit :
Just as an aside: Photoline allows you to use all its tools in 16 bit and even 32 bit.
Nothing in the menus is ever greyed out! The program doesn't pester you with Smart Objects, Smart Filters,
separate workspaces for Raw-Editing and such.
It is clearly among the ugliest programs I ever looked at (tough, really), but conceptually it's it pretty elegant.
And dirt cheap. Maybe worth a look - apparently even the Maxwell for Photoshop Plugin works.
Un programme qui est très bon marché (59 euros) et qui marcherait complètement en 32 bits sans avoir besoin d'une version "Extended" ça vaut le coup d'y jeter un oeil.
Un aperçu de l'interface du programme en page 57 du pdf ici : http://www.pl32.fr/doc/Manuel%20Utilisateur.pdf
On a le droit à 30 jours d'essai gratuits pour tester. Le programme ne fait que 18,9 Mo sous Windows. Installation très rapide garantie !
Edit 2: Après installation, je ne vois que de l'import en 16 bit-color et je me demande comment installer le plugin Maxwell pour Photoshop dessus... Affaire à suivre donc. :mrgreen:
shmums
Re: 32 bits...
Message 10 déc. 2014, 21:52
Bonsoir à tous,
je profite de ce topic pour faire part d'un problème.
J'ai installé le plugin pour photoshop. l'orsque je sélectionne un MXI ce dernier est bien reconnu en revanche le plugin ne fonctionne pas du tout en 32 bits j'ai un message d'erreur qui est le suivant :
" La commande créer n'es pas disponible"
Quelqu'un a -t-il déjà rencontré ce problème?
